ArubaOS and Controllers
Plan under 3600 controller
Hi all,
thanks in advance for all that will help.
Under my 'Plan" options in the 3600 i have imported the corresponding building layouts and placed the 105APs approximately where they are physically located. On the plan i get the following colors on the AP listing under the heat map. One is green and the other a combination of colors. has anybody seen this?
How Many APs?
How many aps do you have in the plan, and how far are they apart?
Re: Plan under 3600 controller
CJoseph,
Its four floors. All aps are 105
1st. floor-left wing 1 ap-105
2nd floor - left wing 1 and right wing 1- about 80ft apart
3rd floor - left wing 2 (15 feet apart) and right wing 2 (30 ft apart)
4th floor. none
thannks
