ArubaOS and Controllers
Occasional Contributor I
Possible MAC issue in 6.1.1.0
We've had a few association issues with 6.1.1.0. Today I found a possible MAC aging or clearing issue. My iPhone wouldn't connect to our WPA SSID. When I looked in the Process Log, it reported:
Jun 21 10:23:33 authmgr: <522025> |authmgr| MAC=90:27:e4:4b:cd:39 IP=10.255.255.35 MAC spoof from MAC=90:27:e4:4b:cd:39
The ARP table only had the correct 10.255.255.35 entry, however. The station table did report:
7:22:49 Yes Print-Area l3guest-aruba a-HT No default-open
90:27:e4:4b:cd:39 jperez
Which is an entry that is 7 days old... I got around this issue by disabling the IP spoofing protection with no firewall prohibit-ip-spoofing, but this is far from ideal. Bug?
Re: Possible MAC issue in 6.1.1.0
Please open a case so that TAC can determine that. If we trigger an ip spoofing event and no ip is being spoofed, it is a bug and you should open a case so that it is looked into.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
