ArubaOS and Controllers
Print Info for guest personalization
Hi all,
is it possible customize the "print info for guest user" page, adding for example the text of "Acceptable use policy" and custome logo ?
Gionata
Re: Print Info for guest personalization
You can configure this from the GUI by clicking Configuration > Access Control > Guest Access. From there, you can import your logo and set policy text in HTML format.
Is that what you needed?
I am assuming you are asking about the controller and not Airwave.
Right !!! Many thanks, I'm very junior with Aruba :(.
Ciao
Gionata
