ArubaOS and Controllers
Occasional Contributor I
Problem to change language at guest captive portal
I try to change language for Portuguese at internal portal authetication of Guest User (login by e-mail) . When I upload html file changed of source code of html, stop to work authentication. I try to upload the page of souce code withou any change and the same problem happen. Some tip for these sistuacion?
I change to Portugues the intenal page of portal Registere Users (login and password) all it´s ok.
The problem just happen for GUEST USER. I think that surce code not be complete? Maybe some part of code must be change.
Thank´s
Re: Problem to change language at guest captive portal
What version of ArubaOS did you try it on?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Hi
I Try with 6.0.0.0 and 6.0.1.2
Do you just save the html after you click on "View Source" in the browser? It should work....
Hi
I did exactly how you write. A fast test that can you do, to see the problem is get the source code and upload at controller (without do anychange) . After that try to login at GUEST USER, you will see that stop to work.
Could you do this test and if the problem persist , explain what is wrong ?
Thank´s
You are right. When I do it like you say, and then upload it first, it does not work. The ArubaOS user manual has a Language Customization Section which shows you how to do this from scratch.
Hi
I tried o consult the UG before and at same way not work. For REGISTERED USERS not problem , work perfect.
I tried too open a ticket at support (number: 1232403). And not help.
So I try to put here the problem to see if anyone know how to solve this.
Some news ?
Some tips?
If you have a case already open, you can request to have it escalated at any time, to help resolve your issue.
