ArubaOS and Controllers
Occasional Contributor I
Problems with A200 5.0.2.0 and HP 8000 series switch
I had problems with A200 v.5.0.2.0 and HP 8000 series switch.
All AP's were directly connected but they were booting quite often, reason: can't connect to controller.
Anyone else with same problem? We changed switch and it works fine now. But would like to know why?
- Joakim
Re: Problems with A200 5.0.2.0 and HP 8000 series switch
Sounds like either a config problem on the switch, or the switch itself was bad. Did you swap it out with another HP or a different brand? Any way to run a self test on the HP?
-awl
Andy Logan, ACDX
Director, Strategic Account Solutions
Aruba Networks
- Joakim
Hi Dude,
Can you upload the following, Switch Configuration VLAN and DNS Entry.
