ArubaOS and Controllers
Contributor II
Public Certificate question
I followed the user guide to import a Public Certificate to the Controller. Everything looks fine there, but how do I get the WebUI to use this? I still want users to login, but I want https://aruba-master to use the imported Certificate.
Under SSH login I have 'Client Public Key' checked. Under WebUI management I have 'Client Certificate' checked. I've restarted the controller, but I think I'm missing something.
Also, is there anyway to turn off http and only allow https?
I've been searching the UG, but haven't found it.
Any help would be greatly appreciated.
