ArubaOS and Controllers
Pulling configs from a controller
Can anybody tell me if it's possible to retrieve a file from a controller's flash by way of FTP/SFTP or similar?
What I'm looking into, is a query from a customer who wants to automate backups of the controllers configs (default.cfg) to a management server (NOT Airwave!).
I don't think the Aruba OS has anyway of scheduling a task like this, so I'm thinking the management server (assume a generic FTP/SNMP thing) would have to pull it? Is that possible?
Any ideas?
J.
Re: Pulling configs from a controller
You might take a look at RANCID http://en.wikipedia.org/wiki/RANCID_%28software%29
I know it takes a bit of tweaking to get it to work right with Aruba, but that should do what you're looking for...
-awl
Andy Logan, ACDX
Director, Strategic Account Solutions
Aruba Networks
Forgot to add the direct link as well: http://www.shrubbery.net/rancid/
-awl
Andy Logan, ACDX
Aruba Networks
Kiwi Cat Tools
Any ideas?
J.
You also use Kiwi Cattools to do this. You can login to any controller an execute commands, along with macros. http://airheads.arubanetworks.com/vBulletin/showthread.php?t=897
That's pretty helpful. Thanks. It might be interesting to know if any customers have filed an RFE for a feature of this kind. But that's really just out of curiosity!
I don't think I've ever heard of an RFE for this, mostly because there are tools like the one's that Colin and I referenced that handle the job already. Any reason the customer is looking to do it this way as opposed to a management system that already exists?
If they are really set on doing it via FTP you could automate a system to log into the controller using something like tcl/expect and back it up that way. I think the biggest issue is going to be making sure the file is named correctly with a controller and date so you don't get mixed up as to which file goes to which controller and to make sure you don't overwrite the old file with the new one.
-awl
Andy Logan, ACDX
Aruba Networks
We use autoexpect.
jason
How do you store/manage your configs once you've downloaded them from the controller?
-awl
Andy Logan, ACDX
Aruba Networks
