ArubaOS and Controllers
RAP issue with 802.1X auth?
So here is the deal:
Our controller is at our HQ in Dallas. We've deployed some APs to our NY office. We've put them in bridged mode on their own SSID. If we do WPA2-PSK it works fine. They get an IP address from our NY subnet and work fine. However, if we do WPA2-AES and have them authenticate back to the Radius server in Dallas, they never get an IP address. They just get a 169.254 address. I've looked at the Radius logs and don't see anything.
We do have firewalls between the 2 sites, but we've allowed full access from the NY office to the controller and the radius server.
I see the following on the controller:
Mar 2 09:22:14 station-down * 00:21:6a:02:6f:9a 00:24:6c:b0:c5:f8 - -
Mar 2 09:22:15 station-up * 00:21:6a:02:6f:9a 00:24:6c:b0:c5:f0 - - wpa2 aes
Mar 2 09:22:15 eap-id-req <- 00:21:6a:02:6f:9a 00:24:6c:b0:c5:f0 1 5
Mar 2 09:22:15 eap-start -> 00:21:6a:02:6f:9a 00:24:6c:b0:c5:f0 - -
Mar 2 09:22:44 eap-id-req <- 00:21:6a:02:6f:9a 00:24:6c:b0:c5:f0 1 5
Mar 2 09:17:44 :132030: |authmgr| Dropping EAPOL packet sent by Station 00:21:6a:02:6f:9a 00:24:6c:b0:c5:f8
Mar 2 09:22:14 :132197: |authmgr| Maximum number of retries was attempted for station 00:21:6a:02:6f:9a 00:24:6c:b0:c5:f8, deauthenticating the station
Re: RAP issue with 802.1X auth?
What is the latency between the access point and the controller? Some clients do not work with more than 100ms latency.....
Average is about 60-65ms. I just realized CPSec is not enabled. Is that required? I want them to utilize local resources for Internet, file serving, print, etc. That would be bridged, correct? Not split tunnel?
If they get a 169 address, do they show up in the user table? If the show up, find out the role the end up in and do a "sow rights " on the commandline and see if dhcp is being allowed in that role.
0.0.0.0 00:21:6a:02:6f:9a logon 00:00:01 Associated(Remote) Narnia-NYC/00:24:6c:b0:c5:f0/g Narnia-NYC-aaa_prof bridge
Derived Role = 'logon'
Up BW:No Limit Down BW:No Limit
L2TP Pool = default-l2tp-pool
PPTP Pool = default-pptp-pool
Periodic reauthentication: Disabled
ACL Number = 1/0
Max Sessions = 65535
Captive Portal profile = default
access-list List
Position Name Location
1 control
2 captiveportal
3 vpnlogon
control
Priority Source Destination Service Action TimeRange Log Expired Queue TOS 8021P Blacklist Mirror DisScan
1 user any udp 68 deny Low
2 any any svc-dns permit Low
3 any any svc-papi permit Low
4 any any svc-adp permit Low
5 any any svc-tftp permit Low
6 any any svc-dhcp permit Low
7 any any svc-natt permit Low
8 any any svc-sec-papi permit Low
captiveportal
1 user mswitch svc-https dst-nat 8081 Low
2 user any svc-http dst-nat 8080 Low
3 user any svc-https dst-nat 8081 Low
vpnlogon
1 any any svc-ike permit Low
2 any any svc-esp permit Low
3 any any svc-l2tp permit Low
4 any any svc-pptp permit Low
5 any any svc-gre permit Low
Expired Policies (due to time constraints) = 0
type show user-table verbose and send the line with that user.
IP MAC Name Role Age(d:h:m) Auth VPN link AP name Roaming Essid/Bssid/Phy Profile Forward mode Server Vlan Bwm
0.0.0.0 00:21:6a:02:6f:9a logon 00:00:01 Associated(Remote) Narnia-NYC/00:24:6c:b0:c1:90/g Narnia-NYC-aaa_prof bridge 167 (167)
Is VLAN 167 where you want that user? That is where it is placing him. Is there DHCP on VLAN 167?
Yes to all.
Okay. When bridging traffic VLANs are a little different. If you have users getting place on VLAN 167, that RAP expects to be placed on a trunk port and it is tagging all of the user traffic on that port with VLAN 167. What you need to do is edit that AP-Group, expand AP system profile and edit the Native VLAN for that System Profile and make it 167 so that the AP does NOT send tagged packets out of that port.
