ArubaOS and Controllers
Frequent Contributor I
RAP's and IP Telephony Call Issue
Running RAP 5's on 6000 Controller running Code. I am new to the Aruba technology, I'm connecting Nortel 1040E IP Phones to the Rap's, can make calls from and to the Rap's but not from Rap to Rap, it rings but when either side picks up, no voice.
If I put to wired PC's on the Rap's, they cannot ping each other either. Sounds like I have a security setting in the config that is causing this. Any suggestions would be appreciated...
Re: RAP's and IP Telephony Call Issue
Z - Most likely it's something with the policy the phone is being assigned. You can take a look at the client table on the controller to see which one it's getting, then have a look at the rules.
