RAP wired clients
I have a customer that uses RAP's only for wired connectivity. I noticed that wireless clients show up under Monitoring > Controller > Clients but wired clients do not. Is there any way to get them to show?
Thanks in advance,
Jimmy
Re: RAP wired clients
What version of AOS is on the controller? All my wired clients show up.
Thanks in advance,
Jimmy
You need to make the wired port profile untusted.
Contributor I
Also keep in mind that most wired clients don't authenticate when connecting to the network. Without authentication, you will only see the clients MAC address listed in the Monitored->Clients list. No userID/machineID unless you use some type of auth.
