ArubaOS and Controllers
RAP5WN is not work with ArubaOS version 6.0.xx
I use the RAP5wn connect to the controller650 at port ethernet 1/0
on the controller is firmware 6.0.x.x
the RAP5wn is not up on the controller that is version 6.0
but i use version 5.0.xx on the controller650. the result is work with the RAP5wn.
i saw the rap5wn up on the controller
Re: RAP5WN is not work with ArubaOS version 6.0.xx
Exactly what version of 6.0?
the firmware version on the controller is ArubaOS_6xx_6.0.0.0_25864
Did you reset the RAP before you connected it to the controller? Are there any messages in "show log system all" that indicate what is happening to the RAP?
Contributor I
Not 100% sure but I thought there were some early versions of 6.0 that had issues or did not support RAP connectivity. The issues were resolved in later versions of 6.x... Are you running the latest version of 6.x?
thanks
I connect the RAP5WN to the controller650 that is ArubaOS_6xx_6.1.1.0_28288
the result is the RAP5WN is up
