ArubaOS and Controllers
RAPs 61 not reconnecting after upgrade in OS5
Hi all,
After upgrading my controller 3200 from version 3.3.3.2 to 5.0.3, all my RAP (model 61) are missing.
They stay down.
I found this log :
"authmgr: <199802> |authmgr| ncfg_auth.c, ncfg_role_default:580: no group for authtype VPN"
I tried to change the user role "RemoteAP" to allowall but it's the same.
Anyone have an idea?
Regards
Nicola
Re: RAPs 61 not reconnecting after upgrade in OS5
Please open a case so that you can get that looked at, especially if it is causing an outage....
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Hi there,
Do you have any update on your issue? I am facing the 5.0 -> 6.0 upgrade very soon and I have 200 AP61s!
Adam,
If you are facing an upgrade, please open a case with support so that your config can be reviewed.
aha! I didn't know that was an option!
Thanks again!
p.s. sorry to hijack your thread gounx...
