RF Plan Significance
Does ARM use the RF plan data in any way (ie. the placement of APs relative to each other and their computed distances) or does it only use realtime data that each AP reports (the items shown under show ap arm state)?
I guess what I'm asking is, other than for a visual guide, how important is accurate placement of APs on the RF plan?
