ArubaOS and Controllers
RF Plan question: once? more than once?
i didn't see a forum topic specific to RF Plan as a product, but have a question on its use.
i know it is recommended to begin deployment by using RF Plan at the outset; has anyone ever used it after an initial deployment? i would like to hear from those who have followed the "RF Plan > Deployment > RF Plan > further deployment" path as well as the "Deployment > RF Plan > further deployment" path. Are there any particular gotchas or problems using RF Plan after initial deployment and importing it into the Controllers or MMS?
Bill
