ArubaOS and Controllers
MVP
Reboot controller after changing clock?
When I adjust the clock on my controllers the system warns me I need to reboot the controller.
Do I really need to reboot or can I safely ignore? Why would the clock actually matter?
Koen (ACMX #351 | ACDX #547 | ACCP)
Re: Reboot controller after changing clock?
If you do not reboot, the timestamps on your logs will not be correct is the biggest issue that I have experienced. I am not saying that you don't have to reboot, but not rebooting immediately does not break anything at that time. I'm waiting for anyone else to comment.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
