ArubaOS and Controllers
Contributor I
Rebooting cause: Datapath timeout
I have an Aruba A200 that reboots continously. The "Reboot Cause: Datapath timeout".
The code was ArubaOS 5.0.3.2. I have formated and load ArubaOS 3.3.3.9 and still have the same problem.
What can I do?
Regards.
Re: Rebooting cause: Datapath timeout
Any time the controller reboots without you rebooting it, you MUST open a support case so that they can get to the root of the problem.
do you have a remote ap with a remote ap peering behind it?
Contributor I
No. I do not have any AP. Only de A200.
Regards.
Did you open a case?
