ArubaOS and Controllers
Release note 27873 ''
Hi, we were/are having authentication issues where the client might take 8sec-2min to logon. After going through release notes from and, i noticed in the 'Known Issues' section of the release notes '27873' "With some clients, client authentication can sometimes take from 30sec to 2 mins."
'some clients'? I would think this to be a important bug to fix? anyway If anyone has any suggestions on a fix or maybe going to 5 ?
Contact Support
Please contact support. It is not clear if the bug applies to you.
Colin Joseph
Aruba Customer Engineering
