ArubaOS and Controllers
Removing AP Licence and Reusing on Other Controller
Does any one know if I can say remove a Single AP licence I have and don't need on one controller and then use it on another. As this has came up and my boss don't want to spend out on another single licence unless he has to.
Regards
Luke
Re: Removing AP Licence and Reusing on Other Controller
Unfortunately, we cannot split licenses.
Aruba
Yes, licenses can be transferred via the licensing site. Assuming you are talking about a LIC-1-AP license in both cases.
Bad sentence above!!! :)
I meant to say "Unfortunately no, we cann split licenses".
Maybe I misunderstood the issue. If you have un used 1-AP license on a controller, yes, you can transfer that via the licensing site to another controller. If you have an 8-AP licenses (or more), you can't split a single license out and move it to another controller.
No what Jfernyc was on about is what I want to do. So thread closed.
Thanks for such quick repossesses
