ArubaOS and Controllers
Retaining floor plans (jpg images) and AP position after an upgrade to
I'm upgrading from Aruba OS to I have a master and local controller in my test lab. I created three bldgs with one floor per building and one AP per floor. I imported a bitmap for each floor and positioned each ap on the floor and saved it.
I disconnected the local controller from the network and rebooted the master to I consoled into the local and rebooted it to I attached the local back to the network.
When I go to Plan, the only entry is for "Main Campus" with no buildings.
I'm going to try the "clean sheet" upgrade procedure next and see if it retains the floor plans and AP position.
Its going to be a lot of work reimporting the bit maps for each floor and manually positioning each AP. Any help would be appreciated.
