ArubaOS and Controllers
Rogue Containment affecting Cell phones?
Are there any situations where rogue containment can interfere with the signal strength of a cell phone?
How do you identify what IPS activity has occured in the controller and if something was being contained as a rogue?
I do see a list of suspected and contained rogues in Airwave, but not sure how to see this at the controller level, and what AP is remediating the client.
Enviroment: Aruba 3200 OS 5.x with AP105's, and Airwave MS.
Wireless Log
"show log wireless " will show this, but the controller does not keep much historical information and so logs from too far back will "roll". Send it all to syslog and examine.
Re: Rogue Containment affecting Cell phones?
This is good info.....
This shows ADHOC's being detected, but not remediated.
In the past, I have set some rogues to "Contained Rogue" from the Airwave management console. I still see a few of these broadcasting.
How do I know if they are truely being contained?
Is there a cli command to show the list of contained rogues and show that some are being remediated?
Rogues Contained
show ap monitor active-laser-beams
