ArubaOS and Controllers
Rogue detection and notification/logging
Not sure if this is the correct location for this question, but here it is.
I need to be able detect and log (syslog) when a rogue AP is active on my network. I have purposely installed a couple of non-Aruba APs to get logging setup correctly. The problem I am having is that I can see the AP as interfering, but it never gets detected as a rogue. Once the detection is corrected, what logging settings do I need to set to get this information sent to my syslog machine?
Thanks in advance.
Re: Rogue detection and notification/logging
When you say "corrected" what do you mean?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Currently the Rogue(s) are not being classified as rogues, just interfering. So corrected means getting the Aruba to correctly classify the rouge AP as a Rogue.
For what it's worth.....Way back when I was running a 2.x release of the OS, the Rogues were classified correctly, ever since going to 3.x releases, I have not seen any Rogues classified as rogues, just interfering.
There are a few more ways to classify rogues, as the behavior and types of rogue access points has also changed over time. The wireless intrusion protection chapter of the user guide details the additional options that you can turn on for classifying rogue access points. It will also detail what those options are..
Do you use dedicated air monitors (AM) with thin access point's for your clients, if so then as long as the rogue AP is 'seen' by a specific AM on the same wired subnet and in the air, then it should be detected in seconds.
If you do not have dedicated AM's then a scanning AP may take minutes to find a
rogue operating on a different channel, or it may never discover the rogue at all. This is because a lightly used rogue AP may not generate traffic during the brief period an AP is monitoring that channel.
Also I had an issue where test rogues were not being detected and this was because on a converged network that is fully routed to the desk an AM is needed on every separate data subnet/VLAN, we had some switches (and therefore some data VLAN's) that didn't have a dedicated AM.
I don't auto contain rogues because I now have email alerts when a rogue is detected and can then locate it before the offender removes it because they have no connectivity.
I hope that helps.
Moderator
Terminology can get a little tricky in this instance. AirWave will allow you to define a rogue however you want. That could be a device using your SSID or on your LAN or anything heard wirelessly, etc.
In this case I think you are using the controllers definition of 'rogue' which is a device that is connected to the wire and discovered wirelessly. There are a few different ways we detect them.
One of the ways is alluded to by Tufty. The APs, AMs and Controller listen to information on the wire and compare that with what is heard coming out of a rogue AP over the air.
In early versions of AOS you needed to trunk all of your vlans to the AMs/APs so that they could get visibility into the wired traffic. In AOS 6.1, you need to trunk the vlans to a single AM or a single AP or to the controller. One AP or AM or controller will share the discovered wire information with all of the other devices on the controller for device classification.
Another thing to be aware of is having clients associated to a rogue AP will help it get discovered significantly faster since we are looking at the traffic coming out of the rogue.
That isn't including any of the ways that AirWave can detect wired rogues. If rogues aren't getting detected I would recommend following up with TAC to make sure everything is configured properly in your system.
I did get the ROGUES to be detected, so now I would like to have a notification sent (email, text, etc.). Currently, I need to be logged into the controller in order to see the rogue detection. Is there any way to have the controller send this info automatically (either directly to an email or to a syslogger)? We are looking at Airwave...will that do this notification?
Thanks!
