ArubaOS and Controllers
Rogue wireless detection - high RSSI
Has anyone else seen where when they are looking at a rogue AP the RSSI of an Aruba AP that barely sees that rogue is 253 or 254 RSSI? The problem is that when you try to "Locate" the rogue it loads the plan image of the one AP which has the 253 RSSI, not the one that is the most accurate.
I've had this happen quite a bit and it's getting annoying.
