Frequent Contributor II
Rouge APs
Hi, my new system has spotted a rouge AP, but does the AP have to be on the same subnet as the Aruba APs to be flagged? If the rouge is on another subnet that the switch can see, could that still be flagged up? Ie. new Arubas on 10.22.2 and rouge could be on 10.23.3 but both visable from switch over the wire.
Also, when using reports there seems to be lots of options for rouge and interfering APs, like Set As.... and Disable. What do these do and what should I do about the interering APs?
