ArubaOS and Controllers
Frequent Contributor I
Running out of ips on a /23 subnet
I have a 3600 controller with about 125 Remote APs connecting via split tunnel. I am running out of IP addresses. The current vlan is a /23, when I go to add another vlan to the VAP it gives an error:
" Error processing command 'wlan virtual-ap "test-vap" vlan 106,103':Error: Remote-AP "split-tunnel" virtual-ap must have exactly one vlan configured "
If I can't add vlans because they are split tunnel remote aps do I have any other options besides making the vlan a /22? Can I somehow add another vlan? I saw vlan pools in the gui but not sure how that works...
Re: Running out of ips on a /23 subnet
Vlan Pooling is not allowed on a split-tunnel SSID. You would have to make it a /22, or create another AP-group, where one ap-group has a virtual AP assign clients to one 23 and another assigns clients to another /23. Assign some APs to one group and the rest to another.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Super Contributor I
Why is vlan pooling not allowed on a split-tunnel virtual-ap? The device gets an address from the controller (not local) so what difference does it make?
Ryan Holland, ACDX #1 ACMX #1
The Ohio State University
Vlan pooling was not designed and tested with split tunnel. Vlan pooling works fully with tunnel at this time. It is not trivial to add and test Vlan pooling for split tunneled clients.
