ArubaOS and Controllers
S3500 Switch Default Gateway
What is CLI command to set the default gateway for hte S3500.
Searched all throughout the 7.0 user guide. Its not in there.
thanks
Re: S3500 Switch Default Gateway
thanks
ip-profile
default-gateway x.x.x.x
Thanks for the heads up on the UG. I'll check with our team about that.
-joshua
Aruba
Default Gateway on S3500
For the default gateway on the S3500, you should be able to configure as follows:
ip-profile
thanks for the command.
didn't check the ip-profile sub directory.
