Occasional Contributor I
SSH and long output
If I logon to my controller with SSH (puTTY) and issue a command like "show ap bss-table", the resulting output is too long to be shown all at once and it will print a number of lines, then:
--More-- (q) quit (u) pageup (/) search (n) repeat
Is there anyway to tell the controller or SSH client to print out all at once?
Thanks in advance!
Re: SSH and long output
Use no paging command ? :)
ACMP 6.4 / ACMX #107 / ACCP 6.5
exactly what I was looking for!
