Session-Flood
I am running AOS 3.4.0.5 and I have many users being blacklisted due to "session-flood". Where can I adjust this feature? Statefull firewall...IDS setting? I have looked, but maybe I am missing something..?
Re: Session-Flood
Check your Stateful Firewall configuration. You may need to adjust your "Monitor IP Session Attack" setting.
firewall attack-rate session ??
Re: Session-Flood
Thanks. I adjusted the attack rate and now will need to wait and see.
