ArubaOS and Controllers
Setting the wireless Key
Sorry if this is a complete n00b question but its the first time I've had experience with our Aruba controller.
How do I change the wireless key? Which option is it? I'm looking under configuration but can't see anything obvious under security.
Re: Setting the wireless Key
Configuration > (Advanced Services) All Profiles
Then on the right side: Wireless LAN > SSID profile > "the profile you need" and then on the right side should be the pre-shared key for said ssid.
Koen (ACMX #351 | ACDX #547 | ACCP)
Thanks, I literally spent hours looking for it.
I love Aruba for its reliability and speed but they have a lot of work to make the interface intuitive!! :)
Thanks again.
