Occasional Contributor I
Slow Samba Access
Hi gang:
I am new here!
I am currently running 6.1.2.1 ArubaOS and I have 10 AP's with around 60 users that are 'authenticated' via RADIUS. The Samba file server is local in the office and I am getting huge slow downs periodically. I don't have large frame drop rates, always <1% and I am not sure if there is a tweak I can do to speed this up.
I cannot disable multicast/broadcast due to DHCP and Bonjour however.
Any advice would be appreciated!
Re: Slow Samba Access
One other note, all clients are using MAC OSX Snow Leopard or Lion.
Retired Employee
Are you getting the same performance when wired to the network?
Have you tried a non-native file manager to access the samba share? For e.g. muCommander
HT
The performance is MUCH better over wired. I will try muCommander and report back.
Tried with muCommander and it is the same as when I directly download via finder
The best answer to this is a packet capture to find out who is the culprit. MAC OSX has had a history of slow access to file shares. If you just do a search of mac osx samba slow you might be able to get some ideas.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Thanks for your reply. I did that, but everything I found was either an update to sysctl, which I tried, or an update to MAC Samba, and its a Linux server running Samba. But it is supper quick over wired, just slow over wireless.
Okay. Install wireshark on the MAC and do a packet capture of the wireless interface while accessing a Samba Share.
Good idea, will try tomorrow and post my results. Thanks
