ArubaOS and Controllers
Software versions / build versions
Just wondering how how the version number works? When I downloaded it was build 24057, but when I looked today the version was build 24178.
However reading the release notes there is no mention of differences, should 24057 controllers be upgraded to 24178?
Re: Software versions / build versions
Chances are either a quick update was pushed to the support site within the same code train shortly after it was published originally, or the incorrect build was published. The usual practice is that a new version is rev'd when a new release is pushed (from to a minor update of, etc). But what you saw should not have happened, but clearly did.
Jerrod Howard
