ArubaOS and Controllers
Split-Tunneling on a Non-RAP AP
Question... I've got the situation where our organization functions as an ISP for multiple agencie (traffic has to be kept separate via different roles).
I've got an agency with multiple remote sites that I'd like to use split-tunneling at via the RAP capability. They'll always be assigned a role of something like "agency-a-role" on the controller. If I put a firewall rule for the "agency-a-role" that says "route" (keep the traffic local), but the agency user travels to a location where it's just a normal AP (tunneling only... non-RAP), what will happen to the traffic? Will it just be tunneled (ignoring the FW rule to "route")???:confused:
I might add that it's okay if the agency user travels to somewhere else that has an AP because since they're in "agency-a-role", the traffic will egress onto the proper VLAN at the controller for that specific agency.
Patrick
Split Tunneling
Patrick
You can't do split tunneling on a regular Non RAP today. I have seen where you put those ACLs in and the Virtual AP does not come up.
More info on split-tunnel question
Thanks Colin! Let me word it differently... if a user that is role "x" that contains a firewall policy that says "route"... and that user goes to a regular campus AP (one that's not doing split-tunneling), what happens to the user's traffic? Does it just get tunneled since the AP isn't capable of doing split-tunneling? Or... is the traffic dropped? :confused:
Moderator
Use ap group option
What you need to do is use the ap group option for the role. In this case, you add the split-tunnel policy to the role, but use the option that says to activate that policy only when the user is associated to an ap in the rap group.
Kevin Hamilton
Kevin, thanks for the reply! I'll dig around for more infomation on that and see if it fits the bill here. Never used that one before.
I'm going to make a guess here and say you're talking about the user derivation rules to check the "Aruba-Location-ID" attribute? If not that, can you be specific on what you're talking about? Thanks!
Moderator
Re: Split-Tunneling on a Non-RAP AP
When you are creating a role, the role consists of policies. When you select a pre-existing policy, the policy has an option of when it will be active. So for example, you could have a setup looking like this:
user-role myRole
session-acl control
session-acl rap ap-group rap
session-acl allowall
The session acl "rap" will only activate when the user is associated to an ap in the rap group.
HTH,
Kevin
