ArubaOS and Controllers
Step-by-Step: How to build a WLAN on ArubaOS from Scratch
The attached document shows how to build a base WLAN from scratch. For ArubaOS 3.x and beyond.
It covers:
- Initial Controller setup
- Configuring an encrypted WPA2 employee network
- Configuring Roles
- Configuring Firewall Policies
- Configuring DHCP
- Configuring Authentication
Colin Joseph
Aruba Customer Engineering
