ArubaOS and Controllers
Tacacs admin mgmt using ACS5
Does anyone know which vendor attributes are required for tacacs admin authentication. Also, how to set them up on ACS5 and values associated with each attribute.
Do Not need Attributes
You do NOT need to pass attributes when using TACACS.
Re: Tacacs admin mgmt using ACS5
I guess the question is how to segregate access between different users and user groups. If I create the following role condition it works but I don't want to create one for every user - "set role condition User-Name equals "ofilipe" set-value root". I tried the below with the ldap group but it doesn't give me root access. I am allowed to login.
set role condition memberOf contains NSG-LAN-RW set-value root
Radius
This works with Radius, but not TACACs at this time. The Aruba Controller does not act on tacacs attributes. Check out the article here: http://airheads.arubanetworks.com/vBulletin/showthread.php?t=704
