ArubaOS and Controllers
Frequent Contributor I
Unable able to login to WebUI after setting Port-channel
HI All,
I'm unable able to login to WebUI after setting Port-channel.
Before setting port-channel on the controller, the WeBUI access is normal.
However, after configuring port-channel, I'm unable to login to WebUI.
What are the settings do I need to check and set?
Pls advise.
Mike
make the port channel trusted
You need to make a port channel trusted. By default, when you create a port channel, it is untrusted.
Re: Unable able to login to WebUI after setting Port-channel
Yup.
We made it trusted.
We could ping the ip interface.
However we are unable to log in to SSH, tftp and WebUI of the controller.
Michael
Details
Turn off the port channel, and see if you still have the same problem. If the only thing you did was turn on the port channel, making it trusted is normally the issue. If that doesn't work, please open a case; you could have something else going on.
WebUI and Port Channel Configs
Don't know if this is your problem, but on our controller every time a change is made to the port channel thru the WebUI it drops the interfaces from the channel. We have to login thru CLI and add the interfaces back to the PC. Hope this helps.
