ArubaOS and Controllers
Updated firmware to 5.0.4.1
Hi All,
I have recently updated my Aruba controllers OS (2 x 3400 and 2 x 800) from 3.4.2.3. to 5.0.4.1. I have 93 APs connected in my campus.
After the update, I noticed that when i click on the monitoring\controller\Access points, i only see those APs connected to this controller. If im not remembered wrongly, before the update, i was able to see all 93 APs connected.:(
Is this a bug or a new feature? :confused:
Can someone give me some advise? :D
Re: Updated firmware to 5.0.4.1
Hi All,
No. Anything under Monitoring> Controller is ONLY on the current controller that you are currently logged into.
The Main Monitoring Screen on the master should have a count of all your access points.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
