Upgrading
Hello all,
I have a 650 controller and several AP-105.
My controller is running 5.0.2.0 and I want to upgrade to 6.0.1.2 and I have few questions.
Can I upgrade directly to 6.0.1.2 ?
To upgrade AP os, do I need to download something else or latest version is included in the controller OS file ?
I see on the 650 controller two paritions (0 and 1). I suppose the right thing to do is to upgrade one parition to latest and keep the other one as a backup ?
If I upgrade the OS, I suppose the configuration will be modified because of old commands removed or new commands added. If I going back to old OS version, I will need to upload my old config ? Or configs are stored on each partition ?
I'm new to aruba and a little lost...
thanks !
Frequent Contributor I
Re: Upgrading
Hi Vincent,
You should check out the release notes for ArubaOS 6 on Aruba's support site. Most of your questions are answered there. In short:
Yes, you can upgrade directly to 6.0.1.2. The APs upgrade themselves automatically from the controller. You should upload the new OS image to the non-boot partition (show image version on the CLI). Save the current config - either to flash or a TFTP server - before upgrading and if you run into problems you can rollback to the old code and config. The upgrade should go smoothly; the changes from ArubaOS 5 -> ArubaOS 6 are not that drastic.
Re: Upgrading
thank you !
I will try it this weekend!
Re: Upgrading
Ok I just did the upgrade. Everythig went well. No error but...I have a problem.
My APs aren't detected anymore in my controller. I looked at the logs via console port on APs, no error. They boot normally, get their IP adresses, etc.
any idea ? I rebooted the controller on my old version 5 and everything works.
Re: Upgrading
How do the access points discover the controller, via DHCP, DNS???
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Re: Upgrading
dhcp
Re: Upgrading
Okay. See what is happening on the controller by typing "show log system 50". Also type "show datapath session table" to see if any of the access point traffic is hitting the controller. Also type "show controller-ip" to see what IP address the APs should be hitting the controller on.
Re: Upgrading
at the end of first command
pr 30 20:43:20 :399816: |fpapps| poe download start
Apr 30 20:43:48 :306510: |publisher| Dropping message from 8214 for service '51 (service not found)'
Apr 30 20:43:48 :306510: |publisher| Dropping message from 8214 for service 'aaa-idle-user-timeout (service not found)'
Apr 30 20:44:00 :313078: |fpapps| XSec Vlan Interface 103 not found line 878
Apr 30 20:44:00 :399816: |nanny| Received the PAPI_APP_SPAWN_PROC Message
Apr 30 20:44:06 :306510: |publisher| Dropping message from 8214 for service '51 (service not found)'
Apr 30 20:44:06 KERNEL: 2:<4>process `snmpd' is using obsolete setsockopt SO_BSDCOMPAT
Apr 30 20:44:07 :319011: |sambawrapper| RemountAllPartitions: Remount Failed for hp-v255w-AA121A0C00001162_p1
Apr 30 20:44:08 :306510: |publisher| Dropping message from 8214 for service '51 (service not found)'
Apr 30 20:44:09 :325022: |authmgr| Bogus VLAN ID:4095 received.
Apr 30 20:44:09 KERNEL: 1:<4>process `trapd' is using obsolete setsockopt SO_BSDCOMPAT
Apr 30 20:44:10 :399803: |msghh| An internal system error has occurred at file msghh.c function msghh_papi_rcv_cb line 79 error Unexpected message from 127.0.0.1:8405 code 0.
Apr 30 20:44:19 :304001: |stm| Unexpected stm (Station management) runtime error at data_path_handler, 641, data_path_handler: recv - Network is down
second command, I see a lot of IPs but not related to my wireless networks. It's IP from my wired networks probably hitting the controller.
third command is the right IP of my controller
edit : from the controller, I can ping AP
Re: Upgrading
Do a 'show datapath session table to see if the AP is even contacting the controller.
Re: Upgrading
X.X.X.254 1.1.1.1 17 8211 8211 0/0 0 0 0 1/5 8 FC
1.1.1.1 X.X.X.254 17 8211 8211 0/0 0 0 1 1/5 8 FY
X.X.X.253 1.1.1.1 17 8211 8211 0/0 0 0 0 1/5 9 FC
1.1.1.1 X.X.X.253 17 8211 8211 0/0 0 0 1 1/5 9 FY
is it normal to have destination IP as 1.1.1.1 ????
