ArubaOS and Controllers
Frequent Contributor I
Uplink enabled not allowing default-gateway?
I've had an issue recently on a 600 controller whereby the uplink has been enabled by default, but not configured uplink wired vlan 1? This has prevented us adding a default-gateway as it complains about the default-gateway not being in the uplink vlan?
My question is, why is this enabled by default and why does it not accept the default-gateway?
Any assistance or information would be great?
Any amount of Kudos will be greatly appreciated!!!
