ArubaOS and Controllers
Contributor I
Upload .js files for use with Captive Portal
Hi;
Using 3.4.0.6, can I use the 'captive portal / upload content' feature to upload javascript (xxx.js) pages used in conjunction with our captive portal?
Will they maintain their original file name and not be changed into one of the many hashed file names?
You can
yes you can. It will not change the filename.
Contributor I
Re: Upload .js files for use with Captive Portal
Cool! Thanks
