ArubaOS and Controllers
Using certificate based ssh login
i see in the 3.3 UG that this is supported. Has anybody used openssl to generate a pem cert and then used it for ssh logins? I use a dsa pub/priv key for all my *nix boxes with scripted daily status checks, etc. Given the number of times that i have typed my password at the prompt this would be a helpful piece of information.
