ArubaOS and Controllers
Contributor II
VLAN 1 does not exist warning
The webinterface warns me that VLAN 1 does not exist. Pretty sure it does actually ;) This is how i configured VLAN 1:
interface gigabitethernet 1/0
description "GE1/0"
trusted
trusted vlan 1-4094
switchport mode trunk
switchport trunk allowed vlan 1,105,202
no spanning-tree
interface vlan 1
ip address 172.16.30.51 255.255.255.0
no ip routing
Anyone an idea why i get this warning?
Re: VLAN 1 does not exist warning
Can you post the output of "show vlans"?
Contributor II
VLAN Description Ports AAA Profile
1 Default GE1/0-3 Pc0-7 N/A
105 ZM_Contractors GE1/0 N/A
202 ZM_Officenet GE1/0 N/A
Vlan 1 is the switch ip. Is there a reason why you have "no ip routing" on vlan 1?
Contributor II
I don't want the 3200 to route between vlans, so I disabled routing on all interfaces.
edit: I tried enabling routing on vlan 1, this does not make the warning go away.
Okay. Fair enough.
What version of code is this, and what was the last thing that you did before the message started appearing?
Contributor II
I can't recall which change caused this warning :o
The controller version is;
ArubaOS (MODEL: Aruba3200), Version 6.0.0.1
Website: http://www.arubanetworks.com
Copyright (c) 2002-2010, Aruba Networks, Inc.
Compiled on 2010-11-19 at 17:29:57 PST (build 26126) by p4build
I want to say open a support case, but did you try a reboot, first?
Contributor II
I fixed it.
controller-ip vlan 1 (was controller-ip vlan 202).
Thanks for the feedback.
