ArubaOS and Controllers
VLAN Mobility & Mobile IP - Basic Concept Req
I have been searching around for these two features in AP configuration but up till now i am not able to apply them in practical scenarios. I need to know what exactly is the function of these two parameters, their usage, scenario's in which they are most commonly used...?:confused:
241
IP Mobility
In chapter 20 of the ArubaOS 5.0 user guide there is a whole chapter on ip mobility. You will find your answers there. Either that or look at the Aruba knowledgebase http://support.arubanetworks.com for the term "mobility".
Colin Joseph
Aruba Customer Engineering
Re: VLAN Mobility & Mobile IP - Basic Concept Req
You'll also find a description in both the mobility controller and campus VRDs available on the public website: http://www.arubanetworks.com/vrd
-awl
Andy Logan, ACDX
Director, Strategic Account Solutions
Aruba Networks
Thnx for all the feedback..
