ArubaOS and Controllers
Super Contributor I
VLAN Pooling questions
All,
I have two questions about VLAN pooling.
To pool, is it simply adding another defined VLAN to a Virtual AP profile? If so, do the subnets have to have the same netmask?
I read in this post:
http://airheads.arubanetworks.com/vBulletin/showthread.php?t=956&highlight=multiple+vlan+dhcp
That they had to be the same netmask, but I couldn't seem to find that reiterated in the user guide for 3.4.1.
Thanks for any help you can offer!
-Mike
Re: VLAN Pooling questions
nope... vlan pooling simply load balances associated users to different vlans and keeps track of this... So, you won't add other vlans to your vap profile, you'll :
1-create vlans
2-craate a vlan pool.
3-add your vlans to the vlan pool
4-map your vlan pool to your vap.
That's it.
VLAN Pooling
All,
-Mike
- yes, it is simple as adding another VLAN to a Virtual AP profile.
- They should be the same netmask because the algorithm assumes that all the VLANs in the virtual AP have the same number of clients.
Super Contributor I
All,
Thanks for the replies this weekend! I'm going to implement it tomorrow morning.
-Mike
