ArubaOS and Controllers
Virtual AP forwarding mode
I am setting up a 3400 controller and several AP 93 on different subnets than the controller.
I need 2 SSID's, 1 for the local network which should be bridged to the wired network, and 1 which is tunneled through the controller.
If i choose bridge under tunnel mode for the first Virtual AP, it won't broadcast that SSID.
I have tried to set the Wired AP profile to bridge, and provision it as a RAP, but still nothing.
Am I wrong in thinking that this AP could bridge one SSID, or is that just for RAP's?
Re: Virtual AP forwarding mode
You can have a campus AP bridge traffic. You must first turn on control plane security, and allow all APs to obtain the certificate.
