WLAN sharing
I need more information about WLAN sharing.
I couldn't find more details in the user guide.
Any Info are welcome.
WLAN Sharing
What is WLAN sharing?
Sounds good i am not alone
When you run the Initial Setup Wizzard you have a new option to select AP Groups, All WLAN and WLAN Sharing.
That is under Specify AP group & WLAN
Enter: SSID, ID Radio Type, ID VLAN to use.
Don't know.
I really don't know. If you open a case, please report the results here.
