WebUI Problem
Hi all,
I have a small problem on my 2400 switch, it seems that I cannot connect to it with a webbrowser, but I can with SSH. IE mutters something about certificate issues but then it just fails.
I have tried exaclty the same on another 2400 controller from the same PC and everything is fine so it is controller related.
Both controllers are running V 5.0.3.2 code
After all my faffing around I think it's to do with default certificates.
Please help Obi Kwan Kenobi, you are my only hope ..........
Opps wrong place for that comment :D
Re: WebUI Problem
Please:
- Try a different web browser
- Tell us what the message is.
Re: WebUI Problem
Hi Colin,
I am using FF 4.0 & IE7, as I said they work fine for one controller but not the other. The controllers are totally indepentant serviing different DMZ's.
The error it gives is a page cannot be displayed message in FF after a lot of connecting/ connected/connecting messages in the status bar, in IE I get a wrong certificate error and when I say to continue it just give a error displaying this page.
Re: WebUI Problem
Are you sure that you can reach that controller on port TCP 4343, which is what it redirects to for the user to login securely?
Re: WebUI Problem
Doh, what a fool I am, you are right, we have had our FW / IPS upgraded and it lost all the custom configuring for running encrypted traffic over non standard ports.
I will trundle off an try that in the morning.
Cheers Colin
G.
Re: WebUI Problem
Hi Colin,
much to my embaressment I was correct re the IPS stuff and you were correct in getting me to check it.
Well don't I feel a fool
Thanks for your help.
G.
