ArubaOS and Controllers
Whats in my 6000 Chassis?
I have around 60 6000 controllers around my organization, and would like to go through and document what each controller has in what slot. I know there can potentially be any combination of SC-I, SC-II and M3 cards as well as SFPs. After documenting, I am going to try to standardize them across the board. But I am struggling to determine what is what in the "show inventory" command. :confused:
"show slots"
Try "show slots":
http://airheads.arubanetworks.com/vBulletin/showthread.php?t=1722
To add, if you have Airwave, you can SSH into the commandline of it and type :
on_controllers "show slots"
It will then run that command on ALL your controllers and give you the output.
Re: Whats in my 6000 Chassis?
That's a very useful command, but doesn't seem to be documented in the user guide.
Is there a list of commands which aren't in the user guide?
edit: I mean the AirWave command, not the controller command.
Command Line Interface Guide
That command is detailed in the commandline interface guide in ArubaOS 5.0 on page 1065 and in commandline interface guide ArubaOS 6.0 on page 1030. The example does not show an M3, only a 2400.
Sorry, I meant the AirWave command 'on_controllers' rather than the AOS command.
