about mesh AP
Now I have two AP93 and an AC200,
The AC200 and one ap93 are in the buliding A, and another AP93 is in the Builiding B. NOW I want to let the people in the builid B can connect to the AC200 in the BuildingA . How can I set mesh AP ?
Thank you ver much !
Re: about mesh AP
There is a mesh chapter in the ArubaOS user guide which describes how to do this. The AC200 only supports up to ArubaOS 5.x, but does not require a separate mesh license. You can find the ArubaOS 5.x user guide at http://support.arubanetworks.com. Click on Documentation> Software User and Reference Guides> ArubaOS 5.0> ArubaOS 5.0 User guide.
about mesh AP
Please keep in mind that since the AP-93 is a single radio (2.4 OR 5), you will be meshing back on the same channel as client connectivity. That will degrade the speed in both locations.
I know this means spending more money, but the ideal situation with what you already have would be to purchase an AP-105. Turn one of your AP-93 into a 5Ghz mesh point at the controller site, then use the AP-105 in the remote building to service clients on 2.4 and mesh back on 5.
Zach
Zach Jennings
