ArubaOS and Controllers
Frequent Contributor I
aruba 620 controller and wired captive portal
I have a 620 controller and want the machines that are connected to it via a wired connection on one of the ports to get to a captive portal. I know you can configure captive portal for wireless users, but is there some documentation on how to configure a captive portal for users that are connected to it via the wired ethernet port on the 620?
Re: aruba 620 controller and wired captive portal
Set the AAA wired profile to a profile that contains captive portal redirection in the default role. Then, make either the port (only option prior to 6.1 I think) or the VLAN (post-6.1, if I remember right) untrusted.
