ArubaOS and Controllers
Contributor I
authentication via LDAPS and map to a role
may be the nature of Aruba OS. I can only created up to 10 management accounts in the controller. Is it possible to be authenticated via LDAPS and map it to a role in the controller? Like user name in LDAPS admin.ny and with a role guest-provisioninng role in the contorller. :confused:
Max of 10 admin accounts in a big borporate enviropment is not practical . A company with over 20 sites will definitely need something like this.
Thank you!
Map to a role
Tary,
You CAN use LDAP to map users to a role. First, you define an LDAP server, then place it into a server group.
You can write a rule in the server group that looks at LDAP for the membership:
set role condition groupMembership contains "Network-Admin-Group" set-value guest-provisioning
groupMembership (case sensitive) are one of a number of LDAP attributes that you can use to do admin role derivation. You can find out what attributes are returned for a user from LDAP by doing the aaa query command:
aaa query-user
You should get output like this:
groupMembership: cn=Network-Admin-group,ou=Groups,ou=Departments,o=TMOC
groupMembership: cn=Desktop-Admin-Group,o=TMOC
groupMembership: cn=B&G-Work-Request-Group,ou=Groups,ou=Departments,o=TMOC
groupMembership: cn=OTPS-Budget-System-Group,ou=Groups,ou=Departments,o=TMOC
groupMembership: cn=Registrar-Admin,o=TMOC
groupMembership: cn=Teaming-Program-Group,ou=Groups,ou=Departments,o=TMOC
groupMembership: cn=FWS-Program-Group,ou=Groups,ou=Departments,o=TMOC
cn: username
You can use a derivation role for any attribute listed in the query result.
If you are already using Microsoft's IAS Radius to authenticate your users for 802.1x, etc you may want to skip configuring an LDAP server and re-use that radius server for management authentication using the attached document. If you use this method, you are simply using groups in Active Directory to set roles, instead of inividual accounts. This is better because the user can re-use his username and password from AD to login and access can simply be managed via groups, instead of users being created manually. Finally, the audit trail (https://airheads.arubanetworks.com/vBulletin/showthread.php?t=383) on the controller will have a detailed record of what user, from what IP address made a change.
