built in PPPOE
hi all,
i have read somewhere that aruba controller has a built in PPPOE which can be used as the default gate way is that true
and if so which controller model supports this feature
thnx in advance
600 Branch Controllers
The 600 Branch Controllers here: http://www.arubanetworks.com/products/controllers/aruba-600.php support pppoe. They also support dialing USB broadband cards, as well as plugging in USB storage devices and USB printer sharing.
ALL controllers support plugging into some wired broadband interface and can be used as the default gateway. The article on connecting your controller to a cable modem details this here: http://airheads.arubanetworks.com/vBulletin/showthread.php?t=742
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Re: built in PPPOE
All controllers support single instance PPPoE. In the interface vlan configuration just select 'ip address pppoe'.
